ThunderDan
Well..ended up forgetting to return the one I ordered. Looks like I'll be practicing doing a fret level after all.
Nice glad you got yours sorted out. Which Kaish roller did you get?GEAR It GLP 100 UPDATE -
Quick back-track, these showed up before xmas with big discounts, I paid $68 shipped. Arrived in perfect condition, and on 1st impression I stated it was equal to the IYV spaulted tele that many scored on. I removed the strings, ordered a roller bridge and it sat until a week ago, when I finally got a chance to set it up.
Here are the findings. The Kaish roller was a drop-in and well worth the $12. Pickups needed a height adjustment, which was awkward because there are no springs, as foam blocks and screws are used. While rubbing out the fret board with Howard's Feed & Wax, I noticed the neck had quite an upward back-bow (@ThunderDan check this out as it maybe your actual problem, not the fret level). There was no tension on the truss rod. Cranking "clock-wise" removed the hump and has remained intact. Tuners lubed, Slinky 10's added, and a final truss adjustment, bingo, this thing is a player! The frets have rounded ends and are factory smooth and level.
Pots are minis, but the P90's sound good. Tuners work ok, but if you're gigging, they should be replaced. All and all, the best $68 I've ever spent. Nothing like bottleneck slide and soap bar P90's. View attachment 281736
Is there an advantage to the roller bridge? Or just a personal preference thing?@ThunderDan View attachment 281880Amazon $13.99. New inserts fit the stock mounts without removing them. Bridge drops on, works great.
