Ok, I admit it.... I'm All Funked Up....
I really liked the harmonics on your first version, Reverend. The second version sounds great, but I'll need to listen to these when I can focus... the household is a bit hectic on the weekends.
I haven't thought about how it might change the sound to run through a real amp.
I just run my guitar into my pedalboard, from there into a Line6POD, and then into the Scarlett2i2.
Sometimes the problem for me is option paralysis. There's so many sounds in the POD alone... I end up setting it to a clean setting and forgetting about it. I noticed I had some weird reverb or echo I couldn't eliminate, even with all the pedals off. I bet it's coming from the POD, duh!![]()
I haven't figured out how to get Reaper to set the grid to the recorded tempo yet, as it would be cool to MIDI synch my Synth too...IMHO, you both did a great job! You both have better chops than me.
BTW, the reason I asked about tempo, when I imported your track into my DAW, it plays it at the tempo my DAW is set to… not necessarily where you played it. I was trying to match your tempo.
Thank you! I sure hope you post a track, too.IMHO, you both did a great job! You both have better chops than me.
